TwinTurbo.NET: Nissan 300ZX forum - Or you can replace the center bearing... (n/m)
on February 04, 2013 at 3:17 PM
Thanks! Now to order a new one piece ds (n/m)
posted by NextZ
on February 04, 2013 at 10:44 AM
In/ out Play in driveshaft at diff connection?
Jkova300z
18:49:59 02/03/13
normal (n/m)
Drk93TT
19:47:38 02/03/13
Is it normal to have a lot of play in the center
NextZ
09:28:53 02/04/13
If stock, no, should be no play at carrier bearing. (n/m)
Zinister1
10:19:50 02/04/13
NextZ
10:44:04 02/04/13
You may want to search and read first. If vibration
zellamay
11:29:35 02/04/13
Or you can replace the center bearing... (n/m) -
15:17:22 02/04/13
I wasn't sure if they were replaceable.
NextZ
16:48:00 02/04/13
I have a Z1 1piece DS, and I have vibrations
MrPulldown(Tahoe)
15:26:54 02/04/13
Go have it balanced, before you kill the trans seal (n/m)
njz
21:03:59 02/04/13
"bucking" as in.....
13:15:46 02/04/13
Yes that is what I was thinking. On/Off throttle jerkiness
Gordo 93TT Daytona
21:34:55 02/04/13
So to clarify, I was stating the bucking was from
Jkova300z
02:02:27 02/05/13
You are describing the symptoms. For more info
Gordo 93TT Daytona
09:35:41 02/05/13
I asked Greg D if he could make me another tune using
Evan_Wright (Ca)
18:25:20 02/05/13
I did not make any changes to timing in the zones that
Gordo 93TT Daytona
19:12:27 02/05/13
Also want to add that none of this would be necessary
Gordo 93TT Daytona
19:30:46 02/05/13
I have the same problems and like you I have spent many
Evan_Wright (Ca)
10:10:45 02/06/13
Yea, ^ that's exactly what I'm referring to. What is that? (n/m)
Jkova300z
02:03:54 02/05/13
Jkova300z
10:33:26 02/05/13
